Sponsored by: CARiD
High Idle On My 22re
Old Mar 10, 2008 | 09:06 AM
92YOTA22RE's Avatar
Guys, just bought my first truck; 1992 22RE! Pumped to get working on it! One of the first things that stood out to me was the high idol. Even after it warms up, it idols very high. The other day my dad and I had the hood popped and he pulled the dipstick, as as soon as he did, the idol dropped to normal. I put my finger over the dipstick hole and as soon as the pressure built back up, the idol went right back up. Any ideas on what this could be? I would say the idol needs adjusted, but its almost as if there is too much pressure building in the crank case. Let me know what ya guys think. Thanks!
Old Mar 10, 2008 | 09:12 AM
rdlsz24's Avatar
Have you tried adjusting the idle? There is a screw on the throttle body. It should idle around 750rpm warm if i remember correctly.
Rob
Old Mar 10, 2008 | 09:14 AM
92YOTA22RE's Avatar
Yea...that idol speed sounds right to me too. I'm going to try the idol adjustment and see if that helps. Wasn't sure if the "high pressure" was part of the problem or not.
Old Mar 10, 2008 | 09:40 AM
4Crawler's Avatar
Might check the PCV valve out. Maybe it is clogged and letting crankcase pressure build up.
redneck17
Oct 29, 2015 09:09 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
ZONAYODA
Jul 13, 2015 07:17 PM
Nickdigg
Jul 7, 2015 06:04 AM
