Sponsored by: CARiD
Hi-Lift Questions? Which one?
Old Jun 17, 2007 | 01:45 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
Originally Posted by FredTJ
So I repeat, why in the world would you use a hi-lift to pull out a vehicle.
I gentle pull with a strap works wonders and is a ton safer or a little bit of winch action.
If you're on flat concrete then I'm assuming that you're at home working on the vehicle. Can we say floor jack and jack stands, much, much, much safer and about as fast.
Fred
in the position chris was in, pulling by a vehicle at the correct angle with a strap was not an issue. we had to pull sideways from inside a lot of trees where a vehicle could not fit. doing it tug-of-war style would not work, so the hi-lift became a come-a-long. i dont see that being any more dangerous than a real come-a-long.
your assumption that im at home when im near flat concrete is not always true, when i'm at home i certainly do use my floor jack and jack stands, but if i have to pull over at a gas station to change a tire, out comes the hi-lift. i dont see that being more dangerous than the bottle jack as long as i'm not under the vehicle, which i NEVER am with a hi-lift.
Old Jun 17, 2007 | 01:49 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
You only really use a hi-lift to extract a vehicle as a last resort. Maybe you're wheeling solo, or don't own a winch. Maybe none of the other vehicles with them is strong enough to pull it out (I've seen this happen, deep deep mud). You make it sound as if using a hi-lift for any purpose is a stupid idea. I have used my hi-lift multiple times on the trail for a trail fix (albeit with a slider adapter). Sometimes you have to do the best you can do to get yourself outta there. I'd like to see a bottle jack that could get up to my sliders and then lift one of my wheels off the ground
Old Jun 17, 2007 | 05:57 PM
dropzone's Avatar
Fossilized
No, one doesn't have to take the photos with a grain of salt.
It's not just the stacked rocks, you've obviously missed the bigger "picture" here.
Even if this was a perfectly flat concrete parking lot this was still just way beyond stupid. He's sitting UNDER the vehicle in some of these pictures.
I've never seen a situation where a bottle jack wouldn't work, to change a tire, where a hi-lift would work, safely.
Why in the world would one even pass a thought about using a hi-lift to "pull your vehicle out".....
Fred
Fred: As a former paratrooper and rappel master in the military I can appreciate your safety first approach but you need to look at the bigger wheeling picture. The bottle jack is not a one size fix all tool. I have used my high lift to help some idiots that have buried themselves to the axle on the beach and had did not have a tow point on their vehicle that I would trust a strap on. High lift got them out faster because it lifted their vehicle higher and faster to get some material under their wheel than digging under a frame with a bottle jack.
If I can use my bottle jack I will, however there are times that using the high lift is the prefered tool for me. I have used a high lift to pull myself out several times because it is the tool I had on hand and it got me the 2-4 feet I needed to go and I have used it to stretch fence wire. The high lift can be used for much more than changing a tire.
People are free to make their choices and suffer the consequences if they make the wrong, unsafe choice. The high lift jack has been a useful tool for a long time. Used and maintained responsibly in the correct situation it works as intended.
Old Jun 18, 2007 | 10:27 AM
Flygtenstein's Avatar
Good high-jack.
Spend the dime on something that will work more often than not, this is not a place to skimp.
I laugh at people who have Hi-lifts but no sliders.
My Hi-Lift is a tool I carry and use when the situation arises. There are many better tools for most situations.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
