Sponsored by: CARiD
View Poll Results: Which Hi-Lift Jack do you use or would buy if you don't have one?
Cast/Steel
35.71%
All Cast
35.71%
X-TREME Jack
28.57%
Voters: 14. You may not vote on this poll
Which Hi-Lift Jack?
Old Sep 29, 2007 | 08:28 AM
yabedude's Avatar
Which Hi-Lift Jack?
I want to buy a Hi-Lift jack, but would like to get feedback on what model is best and why you think that way. There are three models available, with the cast/steel one being more readily available and the one I can easly source. When going off road, I'll mount it outside the vehicle on the front (ARB) bumber, unless I can find a proper roof basket mounting mechinism, but I haven't found one that works yet with my Sportrack basket.
Will the cast/steel model survive as long as the all cast model? What's the pros/cons of each?
Cast/steel model: http://www.hi-lift.com/products/cast_steel.htm
Made of Cast & Stamped Steel Parts.
7000lb (3175.14kg) Tested Capacity.
Available in 36", 42", 48", & 60" Heights.
(91, 107, 122, & 152cm)
Lifts, Winches, Clamps, & More.
All-cast model: http://www.hi-lift.com/products/all_cast.htm
All-Cast Construction.
Available in 42", 48", & 60" Heights.
(107, 122, & 152cm)
Most Durable Design.
X-Treme Jack model: http://www.hi-lift.com/products/xtreme.htm
The Hi-Lift? X-TREME is for the serious Hi-Lift? user, offering the "top of the line" all-cast version (48" or 60" sizes) with special features that include, charcoal metallic powder-coat finish, gold zinc-coated hardware and handle, and a special top winch-clamp-spreader attachment.
Charcoal Metallic Powder-Coat Finish-provides a truly unique look that separates it from the standard Hi-Lift.
Gold Zinc-Coat Hardware-all the hardware, the unique winch-clamp-spreader attachment, and the handle are gold zinc-coated to ensure the greatest rust resistance from extreme use.
Unique Winch-Clamp-Spreader Attachment-replaces to clamp-clevis of standard Hi-Lift?
Winch, clamp, or spread up to 5,000 lbs.
One position for all winching, clamping, and spreading positions.
Last edited by yabedude; Sep 29, 2007 at 08:36 AM. Reason: Cat/steel is more available in my area.
Old Sep 29, 2007 | 06:08 PM
waskillywabbit's Avatar
I have a Red one...with a 48" and 60" bar.
Old Sep 29, 2007 | 08:52 PM
bob200587's Avatar
The all cast would be best all around.....it's what I have in a 48". If I ever get a place outside the truck to mount it I may get a 60" bar also.
Old Sep 30, 2007 | 05:44 PM
88wildrunner's Avatar
the difference in the cast and cast/steel it that, well both bars are the same, when they say cast or steel, its refering to the hook on the end of the bar that you can attach a chain or strap to. i preffer the steel one, becuase when under load if it is to fail the steel plate that is attached to a chain or strap will not break it will bend and twist. and when the cast attachment is under load and fails it cracks in half causing a potentialy harzardous situation. the cast one is probly stronger than the steel plate, but i dont think its as safe.
Old Sep 30, 2007 | 05:50 PM
Kaleb's Avatar
You would think the X-Treme version would have a higher lifting capacity then the other two.
Old Oct 2, 2007 | 10:44 AM
deserttoy84's Avatar
harbor freight farm jack... My friend bought one and it hasn't failed in the past couple years he's owned it.
Old Oct 2, 2007 | 10:55 AM
dropzone's Avatar
Fossilized
Any of those would be fine. You could save a few bucks getting Generic one from a farm store but I would recommend getting the real one. If you have room get the 60". Like anything exposed to the elements you will need to maintain it (lube). There is a plastic case available that is similar to a rifle case that is very reasonable, I just couldn't find the link...
BK2TFUTURE
Oct 11, 2015 08:42 PM
May-39
Sep 6, 2015 01:05 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
shisha1999
Aug 14, 2015 01:33 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
