Sponsored by: CARiD
Blown Head Gasket:
Old Oct 2, 2007 | 10:35 PM
86runner_newb's Avatar
Blown Head Gasket:
I was driving my 86 runner and it started over heating. I pulled over immediately and started checking the engine to notice that the coolant resvoir cap shot off! I was able to start it again then noticed none of the pullys or belts were moving. Unfortunately I made the mistake of trying to drive it to the next exit so i could park it. My uncle checked it out for me i did a tune up, fixed the leaks, replaced the harmonic balancer and crank seal. Now it starts but the gasket is blown. Compression tested and went 80-45-45-30 or close to it. I was going to get a rebuilt head ready to bolt on off ebay bt my uncle thinks it might have a warped head/block or burnt out rings. Any helo will be much appreciated.
Garrett
Old Oct 2, 2007 | 11:11 PM
deserttoy84's Avatar
If your already tearing into the top end then at least throw a set of rings and bearings in it. Just make the sure the pistons are in good shape. Just take the head off and have a reputable shop check it out. the head will more then likely be reusable unless you overheated way too long. What do u mean when u say that nothing was moving after you started it back up again? If the engine is running and the belts are connected everything should be spinning. You must of broken a belt if it wasnt spinning.
4x4-runner
Dec 27, 2016 01:58 PM
Tennesseestorm
Sep 12, 2015 01:37 AM
Flossy
Aug 5, 2015 05:14 PM
toofly1999
Jul 25, 2015 07:09 PM
