Sponsored by: CARiD
hey guys I need some help!
Old Dec 9, 2009 | 01:57 PM
alil2cul4u's Avatar
Hey, I have searched on here and couldnt find anything! I need some help, I was driving yesterday at 20 miles per hour in 4wd high and It started to squeel really loud so I pulled over and put it in 2wd and it went away so when I was able to stop somewhere off the road I looked and there is grease all over looks like packing grease maybe for CV axle or joint?!? I really some help... I will take some pics of what is Im talking about. I was driving in 4wd because of snow and ice.
Thanks
Julian
Old Dec 9, 2009 | 08:44 PM
85TurboRunner's Avatar
CV boot is torn. Remove and replace with a new CV.
Old Dec 10, 2009 | 02:18 PM
Mauzer's Avatar
ditto
Old Dec 10, 2009 | 02:20 PM
clydehatchet's Avatar
x3. dont replace boot, replace whole thing.
Old Dec 10, 2009 | 02:47 PM
Ardent's Avatar
Napa Remans are only $50-75.
Old Dec 10, 2009 | 02:56 PM
okie81's Avatar
Welcome to YT and thank you......for coming prepared with pictures. You wouldn't have gotten such straightforward and definitive answers with just that question alone.
Old Dec 10, 2009 | 03:33 PM
alil2cul4u's Avatar
Thanks guys! I have talked to other people and sent pics to my dad. and he said the same thing... I will most likely replace both CV axles.... both boots are torn and for new CV axles at autozone it is 60 a piece....
Old Dec 10, 2009 | 04:13 PM
muddpigg's Avatar
But the squeeling may not have been the cv shaft. Though it still needs to be replaced. The spindle bearings in these trucks go dry on greese and spueal and grumble when it gets cold. Just make sure you greese the well when you change it.
You didn't list your location but you can find these CV axle pretty cheap from guys like me when we SAS our trucks. I bought 2 for $30 about two years ago. Changing these axles is rather straight forward.
Goodluck and welcome.
Old Dec 10, 2009 | 04:17 PM
alil2cul4u's Avatar
I didnt know how to specify where I am... But I am in Evans Co
Old Dec 10, 2009 | 04:26 PM
muddpigg's Avatar
You didn't have too, but you may want to check craigslist. If you were up this way I got two. Perhaps someone down that way has spares.
What happens is once the boot tears dirt, grit, and water get in and wear out the joint. So it the boot isn't torn and the shaft doesn't have excessive play when twisted its good. It'd save you some coin if thats a concern.
Old Dec 10, 2009 | 05:17 PM
alil2cul4u's Avatar
Im not the one paying it my moms car i just turned 16 and I do all the work she is the one who is buying them.... I have told her there is a possibility that we could get them from someone parting out a toyota.... Can anyone tell me how to change them.. Ive done lots of work on cars but never any drive train
Thanks
Old Dec 10, 2009 | 07:33 PM
muddpigg's Avatar
Look in the faqs section, depending on the year you may be able to download a factory service manual (FSM), I'd go so far as to its a must and hell free or cheap most of the time. The FSM will tell you the long way to swap axles, the driver side is easier than the passenger. Search for "cv replacements" I've seen write ups before, also its a good time to inspect TRE, wheel bearings, ball joints, the other CV. Perhaps you can avoid future issues.
Also search for "spindle lubricator". I made one out of PVC pipe cap worked good till the grease got cold then couldn't pump grease anymore.
Old Dec 10, 2009 | 08:16 PM
alil2cul4u's Avatar
Can you tell me what the TRE is? The ball joints are good, her friend from work was a mechanic and he said that everything as far as ball joints and a arms and brakes were good when he checked... that was only 7 months ago. Oh and I plan on changing both driver and passenger
Old Dec 10, 2009 | 08:33 PM
RobD's Avatar
TRE=tie rod end
Old Dec 10, 2009 | 08:56 PM
alil2cul4u's Avatar
Ok, thanks... That makes sense... I believe the mechanic also checked that. but could be wrong... How do I do this stuff? I cant seem to find any Factory Service Manuals.... It is a 1990 4runner 3.0 V6 4WD
Thanks for all the help you guys have provided!
Old Dec 11, 2009 | 10:00 AM
muddpigg's Avatar
https://www.yotatech.com/forums/f116...l-link-131168/ believe its a torrent.
Old Dec 11, 2009 | 11:34 AM
Mauzer's Avatar
If you wanna just look at an online version you'll find it here:
http://www.ncttora.com/fsm/
Old Dec 11, 2009 | 07:31 PM
alil2cul4u's Avatar
Thanks guys for that... I looks good after I figured out that Opera really wont download .torrent files... had to get BitTorrent. there is alot of great info there Hey this is a bit off the CV subject but can anyone tell me why all my power lock motors siezed all at once? My battery was dieing due to a bad diod in the alternator. I had to push start it. and then my locks would not go up or down I had to take all the door panels off and bend the metal on the motor just to be able to lock them being that I have a stereo system! I have a friend that works for toyota and he quoted me $170 for all the locks lock motors and ignition all pre keyed just to replace the motors. It sounds like a good deal being that my key wont roll down my rear window.
Old Dec 11, 2009 | 08:03 PM
Nogarage's Avatar
Won't your power locks work with a healthy alternator? Seems to me.
Old Dec 11, 2009 | 08:06 PM
alil2cul4u's Avatar
Well thats what we thought. But the motors are completely siezed like I cant move them at all. I tried to force them to move but nothing
