Sponsored by: CARiD
help wheres the temp sender
Old Nov 4, 2011 | 11:15 AM
EFI85's Avatar
Im trying to locate the temp sender for the gauge . my gauge is always sitting at a little under halfway and id like to check the sender because it never fuctuates even when the motor is cold . thanks guys
Old Nov 4, 2011 | 11:16 AM
EFI85's Avatar
btw its 1985 EFI 22RE
Old Nov 4, 2011 | 11:29 AM
snobdds's Avatar
It's on the intake manifold between the 2nd and 3rd piston. It will have a spade clip on it. Just look behind the thermostat housing and you should see it. Taking it off will require the removal of a few vaccum hoses, so note where they came from.
Old Nov 4, 2011 | 12:00 PM
EFI85's Avatar
thanks !!! i found it but im thinking the gauge is the problem . i unplugged the sender and grounded the wire and the gauge did the same thing as soon as you turn on the key it goes to just under halfway and stays there . Im now considering an aftermarket gauge since im not sure if fixing the stock one is something i can even do ..
Old Nov 4, 2011 | 12:19 PM
snobdds's Avatar
Well sounds like your switch is bad...gage gets it's input from the sender.
Old Nov 4, 2011 | 12:47 PM
EFI85's Avatar
switch ??? what would you be referring to ? .
Old Nov 4, 2011 | 02:37 PM
snobdds's Avatar
The thermo sender is basically a variable resistor switch. The resistance goes down as the tempature goes up. Basically the same thing as the thermo switch for the ECU.
I guess call it what you like as long as you know what it is...
coryc85
Dec 5, 2015 08:42 AM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
--Oz--
Sep 6, 2015 01:06 AM
