Sponsored by: CARiD
Gargling nails
Old Sep 8, 2012 | 10:45 PM
LaTour's Avatar
Gargling nails
I got this rattle that comes n goes on my 88 4runner Seems to come around when the engines warmed up and has been driven around. It can get pretty loud.
Its loudest at low rpms. I have noticed the rattle while not in gear as well.
Not the timing chain..
Any ideas where I could look? Ill work on recording the noise if necessary.
Thanks in advance!
Old Sep 8, 2012 | 11:05 PM
wyoming9's Avatar
Red face
Have you looked for anything about to fall off??
Hard to tell about noises .
It could be the heat shield on the exhaust but those are most often long gone.
IS it a rattle or engine knock some rod knocks seem to get quiet as rpm increases:jessica:
Old Sep 8, 2012 | 11:15 PM
LaTour's Avatar
I just bought the truck a week ago, so im in the stages of going through everythin and learnin at the same time.
Ill check the around the exhaust heat shield thanks for the rec!
It sounds like nails being gargled heh.. that's about the best I can describe the noise. Just not a pretty noise.
Ill let ya know in the mornin if that was it. Any other suggestions?
If that aint it ill post a recordin somehow.
Old Sep 9, 2012 | 12:27 AM
bob200587's Avatar
Chances are that it's just an old truck that will make lots of noises.
If not....
I don't know.
Old Sep 9, 2012 | 02:51 AM
dropzone's Avatar
Fossilized
Motor or t/c mounts. Fan hitting radiator?
Sometimes it helps with a better description like 1988 v6 auto
How do know it is not a loose timing chain?
Old Sep 9, 2012 | 05:20 AM
waskillywabbit's Avatar
Someone put nails in the gas tank.
:wabbit2:
Old Sep 13, 2012 | 08:06 PM
Tallt's Avatar
It may be your clutch
Old Sep 14, 2012 | 06:52 AM
highonpottery's Avatar
Tranny? My truck had bad input shaft bearing and sounded like this. At least check to see if it's full of fluid since its a new to you vehicle.
Big Little Bear
230
Nov 13, 2023 11:42 AM
JNapolitano
Nov 14, 2019 07:46 PM
CPD4runner
9
Nov 5, 2017 06:01 AM
