Sponsored by: CARiD
fuel supply cuts out
Old May 4, 2026 | 05:17 AM
Scott Baxla's Avatar
5 Year Member
I've got an 06 tacoma, 4.0L. For years I've been trying to figure out this issue.
I'm not sure if I'm posting this in the right place.
- The events are sporatic - could be months or even a year in between events, but I never know when its going to leave me stranded.
- Twice it was diagnosed as a faulty fuel pump (I"m pretty sure incorrectly diagnosed) , and the fuel pump was replaced ($$$$) - 6 months apart. (2nd time I replaced it with Toyota pump, first time mechanic insisted on auto zone part based on his experience...) So when it does this glitch, the auto shops do whatever test they do to diagnose faulty fuel pump, and it indicates faulty fuel pump. But I'm pretty sure that's not it. The 2 fuel pump replacement events were early in the game - not long after I acquired the truck, so it may have been doing it with previous owner and he dumped his problem on me. The first fuel pump replacement may have even involved running out of gas - I was running low and was looking for an exit to get gas, but my trip meter suggested I had a few miles left. The gas gauge was inaccurate at the time (it has been repaired now), so I used the trip meter to monitor fuel, and maybe at 90-100 on the highway I was using more fuel than usual.
- I've replaced the evap canister, which for a while seemed like maybe the issue went away after that, but it resurfaced again, so that was not it. (is there any sort of a filter associated with the evap canister?)
- Sometimes when I'm driving down the highway (70-80MPH) the engine just cuts out. I've not clearly identified the conditions yet, but it seems like some sort of extra load happens - like going up a significant hill - asking for more fuel. Last time I noticed I was on cruise control, but don't remember if I've been on cruise for previous events. Sometimes its just a hesitation (enough to make me panic) - a hitch and starts running again. Sometimes I have to take my foot off the accelerator and put it back on and that gets it going again. Once that didn't work and I swerved left, right, left, right... and it started going again. 2 times it didn't start running again and got towed in - fuel pumps. Maybe for those fuel pump replacement episodes, I could have gotten it going again by playing with the accelerator pedal or swerving? The first time may have even involved running out of gas - I was looking for an exit to get gas. When they replaced the fuel pump, the fuel take was clean.
- Twice I drove the truck home - everything working normal, parked and went inside for the night. The next morning it would not start. One of those times I had it towed to mechanic a day or so later and it started when it got there (we assumed something got giggled on the tow truck ride). I think I remember that for that episode, I had just filled up at the gas station before coming home and parking. (That led to the suspicion that it could have been evap canister related from topping off the gas past the first click off at the pump.)
- Two days ago on Saturday morning it did this next day no start (no fuel). I tried again later in day and nothing. On Sunday afternoon I was getting things moved around to get ready for a tow on Monday and tried it again and it started. Nothing got giggled, just 1 1/2 days time and it went away.
- The mechanic can't diagnose it if its not doing it... I'm pretty sure its fuel related.
- I've wondered about a connection issue at the fuel pump (why did previous mechanics diagnose fuel pump - they banged on the fuel pump and it started working again?) I don't think me moving stuff around in the truck would be enough to giggle that connection and have it restart 1 1/2 days later.
- I've wondered about a wiring short, but that would not make sense with it starting itself 1 1/2 days later? (This truck has had the frame replaced, and apparently the centers that do that are doing it really fast and other things get crimped and broken...)
- I've wondered about some sort of a vapor lock, but don't know what to look for if it is. Its one of the few things that make sense - if it goes away on its own with time.
- I've wondered about some sort of particle in the fuel system, and once pressure dissipates, the particle shifts and falls away from whatever orifice its blocking? (is there some way to do a fuel system flush?)
- Fuel filter?
Old May 4, 2026 | 12:15 PM
the_supernerd's Avatar
Do you know if the entire fuel pump/float assembly was replaced or just the pump itself?
Does the check engine light ever come on? Even if it is not on, scanning for codes could help if there is a pending code in the computer.
If possible, find out how the mechanics diagnosed the fuel pump. If they tested fuel pressure and nothing else, that could be anything in the fuel pump electrical circuit or a clog somewhere. If they tested the electrical resistance of the pump and it failed, that could also be the circuitry in the assembly and not necessarily the pump. If they just guessed then find another mechanic.
Something floating around in the fuel tank is something to consider, but I would think the strainer would be noticeably clogged when they removed the pump. I doubt a fuel filter would cause problems so intermittently, but it could be possible. Wouldn't hurt to replace it anyway especially if it is original.
Intermittent problems are always a pain to diagnose. Installing a fuel pressure gauge in the cab of the truck so you can see what it does when the problem happens might be a good next step. If it has full pressure, then it is not the pump. If pressure is lost then you know for sure it is in the fuel system.
Since you said the frame was replaced, follow all the fuel lines to make sure none are bent, look for loose or smashed wires, or any loose or corroded grounds. Also check for the same thing in the engine compartment.
Scott Baxla
Jan 30, 2023 01:10 PM
greyheadedguy
May 9, 2019 09:12 PM
runnermedic
Dec 7, 2013 04:15 AM
bennyt4130
Sep 26, 2012 11:08 AM
jeff.turman
Jul 18, 2011 07:53 PM
