Sponsored by: CARiD
fuel problem
Old Jan 17, 2009 | 12:36 PM
dawinksta's Avatar
fuel problem
My 1987 toyota motorhome isnt starting now. it has a 22re engine in it. starting fluid works so its a fuel problem. I tried jumping the Fp and B+ terminals and it doesnt do anything. I will bring it to a toyota dealership as soon as I can. Any ideas of what the problem might be? I'd like to have an idea before I just give it to them and they start charging me per hour. thanks,
~Eric
Old Jan 17, 2009 | 03:30 PM
dawinksta's Avatar
also, when it died I heard a slight click (like a relay) from the passengers side. then it just died as if I had turned the key to off
Old Jan 18, 2009 | 05:50 PM
dawinksta's Avatar
come on now, theres got to be some wise mechanic here who knows about 22RE engines.
A relay sounded like it clicked on the drivers side of the cab.
Anyone else have this intermittent starting problem?
Old Jan 18, 2009 | 07:18 PM
4Crawler's Avatar
Do you hear the fuel pump running with the ignition on and the FP jumper installed? If not, may be an issue with the circuit opening relay which happens to be located in the passenger side kick panel area:
- http://www.4crawler.com/4x4/CheapTri...ORelayLocation
Old Feb 7, 2009 | 05:17 AM
buckhunter's Avatar
i had a similar problem on my 4runner check your starter or it could be an ignition switch gone bad
Old Feb 11, 2009 | 05:31 AM
bipolarandproud's Avatar
X2 I would also suspect the ,"Circuit open relay " Or The ,"Main Relay " Both Are located in the driver side kick panel .
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
