Sponsored by: CARiD
fuel injected 22re idle problems
Old Dec 21, 2012 | 01:06 PM
palmer223's Avatar
hi guys thanks for reading my post. i recently bought a 1994 toyota pickup with a fuel injected 22re and im having problems with the idle. whats happening is it will idle really high (about 1500 rpms) and when i push on the brakes it drops real low then jumps back up again until i let of the brakes then it goes back to a high idle. i have looked on several forums and they all seem to think it is either a brake booster going bad or a bad throttle postion sensor. i dont have the money to replace both so i was wondering if anyone else had this problem and how they fixed it. any help would be greatly appreciated.
Old Dec 24, 2012 | 01:31 PM
thefishguy77's Avatar
Have you checked for vacume leaks. Try taking a can of carb cleaner and spray down your vacume hoses while it's running. When the idle starts to race or he motor dies you are close. Then inspect the ara hoses for cracks. Only takes a few bucks to do. Hope this helps.
Old Dec 24, 2012 | 02:27 PM
brianh699's Avatar
TPS inspection http://personal.utulsa.edu/~nathan-b...34throttle.pdf
Booster inspection. http://personal.utulsa.edu/~nathan-b.../5brakeboo.pdf
Old Jan 29, 2013 | 07:14 PM
palmer223's Avatar
sorry guys i forgot about this post i made. i found the problem to be the idle air control valve was clogged so $100 later it runs like a dream
Old Mar 20, 2013 | 11:19 AM
bhylton's Avatar
im having the same problem with my 95 pickup 22re. idles around 2000 even after running for awhile. how did you test to see of the IACV was cloged? did you just remove it or is there a way to test it?
Charecter1
Nov 6, 2023 10:08 AM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
