Sponsored by: CARiD
front axle ?'s
Old Sep 14, 2009 | 04:58 PM
tomkoas's Avatar
Cool front axle ?'s
so of all the threads on here i don't see any for front sfa pre84. I am about to buy a '81 lifted yota. the owner says that there is a leak by the tire some where. from what i know i would think birfeild seals are shot, so i was hoping to get some in put from other,as far as how easy of a fix is it and what it could be? what other seals are at the ends of the axle? what would be leaking? (gear oil?)
thanks for looking.
Old Sep 14, 2009 | 05:08 PM
88Cleve4runner's Avatar
the reason you haven't seen a pre 84 SAS is because SAS stands for (solid axle swap). pre 86 are already SFA. as fas as the leak goes, i have IFS so i can't answer that. i just thought i'd clear up what i could haha
Old Sep 14, 2009 | 05:29 PM
myyota's Avatar
If you have a leak in the front axle, just buy a complete rebuild kit from marlin crawler, make sure that you get marlins upgraded inner axle seals, there definatly worth getting.
Old Sep 14, 2009 | 05:31 PM
Tofer's Avatar
Sponsor
yep you need an axle rebuild kit. i sell the trail-gear version. let me know if you want to order it.
Old Sep 15, 2009 | 04:47 PM
tomkoas's Avatar
there i fixed it i alway figured that sas stood for solid axle suspension oh well thanks, so tofer how much do the axle rebuild kits run?
Old Sep 15, 2009 | 07:19 PM
Volcom's Avatar
Yup, the good ol' leaky Toyota knuckle
Download this Factory service manual
http://www.ncttora.com/fsm/1985/1985FSM.pdf
Buy a knuckle rebuilt kit from Marlin or Trail Gear and rebuild the front axle. I also would suggest Marlin Crawler's upgraded inner axle seals. They will help keep the knuckle from leaking in the future.
Old Sep 15, 2009 | 07:21 PM
peow130's Avatar
By the way, if you want to run anything over 31" tires, get a different gearing.
the 81 axles came with a 3.90 gearing, and it's a dog with anything over 31"...
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Cabell
Jul 24, 2015 12:14 PM
