Sponsored by: CARiD
Frame and body mount questions. 91 Toyota Pickup
Old Nov 15, 2011 | 09:09 AM
TRayRyan's Avatar
Purchased a wrecked 1991 extra cab toyota pickup that has a lot of work done to it. The cab a-pillar and front structure is all damaged and I am wondering if the cab off of a 2nd gen 4runner will bolt up to the truck frame without major modifications? If not I will be in search of a good cab for the truck to do the swap.
Old Nov 15, 2011 | 09:24 AM
TylerH's Avatar
Should "fit" May have to weld come brackets. And change some wiring. Someone did something like this a year or so ago. It should be in the build up section.
Old Nov 17, 2011 | 08:18 AM
rattlewagon's Avatar
The 4runner body is too short. The extra cab frame is going to have a longer wheelbase than the 4runner. You would have to shorten the frame or stretch the body.
Old Nov 17, 2011 | 11:50 AM
TRayRyan's Avatar
Thank you Rattlewagon! I was afraid that would be the case, and havent had time to measure the two out yet, but that was the answer I was expecting to hear. I have probably spent 1000 hours on yotatech doing research and planning a 4runner build. I ended up buying this wrecked xtra cab, and it already has an lift with SAS, 37's, 4.3 with 700r4, bumper, winch, redone interior etc etc done to it, however it took a pretty bad flop and will need a cab fenders hood and ps door. Looks like its time to rebuild an xtra cab!
6th Gear
19
Dec 10, 2019 07:31 AM
Gamble_STi
Jun 27, 2015 07:54 PM
GorgeRunner
Jun 27, 2015 07:01 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
