Sponsored by: CARiD
Error code 52?
Old May 13, 2013 | 03:33 PM
AndyKrashYota's Avatar
Error code 52?
So im getting error code 52 after i did a HG job on my 93 22re. It says knock sensor. I did fiddle with the dist could that be why or is it something else?
Old Jun 17, 2013 | 12:40 PM
bbrideau's Avatar
check the wire to the plug. the plug is below your intake and above the oil filter and a little to the left. if that wire has any damage it will throw a code. and if the knock sensor is hooped i hope you have a wrecker near by because they are way over priced. not very often the sensor goes tho its usually the wiring. and the wire is a shielded wire hence why if anything frays on it it throws off the signal the knock sensor sends to the ecu.
Edit: I chased down a code 52 for 3 weeks. i got lucky and found a wrecker that didnt know the value of a knock sensor and i paid 10 bucks for it. i might have some pictures of location if u need it
Old Jun 17, 2013 | 01:09 PM
I will give it a look. I had to peice together a distributor from a few different years so my timing is probably off but not too far off
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
