Sponsored by: CARiD
Engine stand
Old Aug 17, 2016 | 08:09 PM
Shadow644's Avatar
Engine stand
I'm pulled my first engine (22re) and I can't figure out how to get it on the engine stand, it's a harbor frieght 1000 pound stand. I can get the bottom 2 bolts to line up but not the top 2.
Old Aug 18, 2016 | 09:38 AM
wyoming9's Avatar
Not having a clue how the Harbor freight one looks you might need to build your own adapter to bolt to the block then slide into the engine stand
I have needed to do that a few times over the years .
Most often you get what you pay for
Old Aug 19, 2016 | 04:41 AM
Terrys87's Avatar
On the top two, I had to sit my adjustment to the half way point. Maybe the picture will help. I went to Lowes and got me 4 bolts just for my engine stands to hold the motor and that is all I use them for. I have 2 HF stands with motors on them.
Old Aug 19, 2016 | 08:53 AM
SacRunner's Avatar
I'm pretty sure that's the same stand I used with my 3.4 swap. You'll need to rotate the "mount plate" and arms, move the arms to different slots until you can align the arms to 4 of the transmission mount holes.
I know its a different application, but here's how mine looked with a 3.4 (it's not totally clear, but it's the best I have):
I didn't know how long of a bolt I needed so I grabbed a bunch of hardened 1/4" thick washers to act as spacers.
Old Jul 15, 2017 | 04:37 AM
Mosstopy's Avatar
Just got to get creative.
The HFT 750-lb stand uses M12x1.25 75mm, some use 100mm.
Toyotabc
Apr 16, 2016 07:24 PM
Old Red 94
Mar 26, 2016 04:31 PM
MudWaspSR5
Mar 8, 2016 03:11 PM
frankenfab
Mar 1, 2016 01:17 AM
Corey
Aug 27, 2002 07:45 PM
