Easy Answers
not to insult your knowledge but these motors can run a lot higher rpm than say your full size chevy. 35's on stock gears will be a dog but i mean if your used to shifting at 2 or 2 and a half grand you got to relearn and your truck will be a bit more ballzy. if yo udont run mud much id yank the boggers and sell them before they wear out(quickly) and are still woryh something and go to a 33 or even a 35 inch mud terrain. if your still not impressed regear but boggers create a lot of rolling resistance compared to your average mud tire. food for thought. going 31's on a truck that high will look a bit off and i feel not necessary
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The only suspension lift for these truck I know of are 4" drop bracket lifts...
So you've got 7" of lift...
It's too bad I hate lifts as much as I do on principal or I might could help you some...
Lifts and tires don't make trucks go in and out of more places... Proper traction (diffs), tires and a driver do...
A winch and lockers should be on a 4cyl truck. Not 7" of lift and 35's.
You either need to regear, or lose some lift. It's as simple as that. And w/o knowing what you want and what you expect out of the truck it's hard for anyone to tell you what you need to do.
I do know the IFS is stronger than internet opinion, and some have used 5:71 gears...
Dang, I keep talking, but you've got a 22RE... So no matter what you do, you'll still be pushing it with 112hp.
punks_is_4x4
Feb 26, 2016 04:29 PM
