Sponsored by: CARiD
E brake cable r and r
Old Nov 7, 2015 | 01:33 PM
rubronthroad's Avatar
A while back My e brake cable was to tight, then it broke, I replaced it and it wasn't tight enough, I adjusted it as much as I could, still doesn't work the way it should, I had the part store check and it seems they sold me the right part, just seeing if anyone else has had this kind of problem.
Old Nov 7, 2015 | 11:51 PM
wyoming9's Avatar
Red face
You have adjusted your brake shoes if this vehicle has rear drum brakes ??
Rear shoes and drums in good working order??
Might be nice to know just what year??
Old Nov 8, 2015 | 07:06 AM
Thanks Wyoming ,this is my 91, yes I adjusted out the brake shoes as much as I could, someone else mentioned some part relating to the e brake that may need some oil, I will give it another check.
Old Nov 8, 2015 | 07:38 PM
Odin's Avatar
Oil won't last long. In your environment you might need anti seize.
Old Nov 14, 2015 | 08:45 AM
Thanks Odin, yes I will use anti seize
Old Nov 29, 2015 | 10:52 AM
Funky butt lovin's Avatar
Any tips to un seize e brake rear 4x4 95 pickup? Lube and a hammer haven't worked.
Old Nov 29, 2015 | 01:28 PM
wyoming9's Avatar
Red face
Time for new bell crank brackets steel pin through a aluminum bracket seizes fast.
Most times I end up cutting the bell crank free of the bracket with a cutting wheel
Clean up the Bell cranks .
New Pins
Never Seize use the e-brake all the time.
edgar62902
9
Oct 15, 2015 11:30 AM
mskater
Oct 13, 2015 09:08 AM
odoyle81
Oct 12, 2015 07:00 PM
Deeraholic
Oct 12, 2015 08:58 AM
krisch
Oct 9, 2015 05:46 AM
