Sponsored by: CARiD
Defeat/Disable Factory Alarm- 1993 Pickup
Old Aug 12, 2012 | 01:35 PM
Noswal's Avatar
This is a new to me pickup (1993 4x4 SR5 V6) and has the factory installed alarm. The rocker switch to the left of the steering wheel is not hooked to anything- the PIN connecter is just hanging. I can't even locate the other end. The alarm goes off every time I open the door, without starting the truck (for example, getting something out of the truck). Then, if the alarm goes off, and the horn starts beeping- I have to jump in the truck and start it. This shuts off the alarm. Is there some way to disable or defeat the alarm? My keys are normal keys- no fobs or electronics.
Old Aug 12, 2012 | 02:07 PM
vital22re's Avatar
totally a bro
if you open the door you have 1 minute to turn on the ignition. If the alarm goes off, you turn the ignition on and off 2 times. If you don't want it, pull the kick panel off on the driver side and there should be the factory harness plugs. Its a t fitting. The actual control box is tucked away on the passenger side. The alarm is more of a nuisance than anything.
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
colinmil
Jul 6, 2015 04:03 PM
