Convert a 2wd to a 4wd?
I have a 01 4runner, 2wd, i have found a tranny, and transfer out of a 99? What else other than a drive shaft would i need to complete this conversion? Sorry if I posted this in the wrong section.
front and rear drive shafts, linkages for shifters if auto. whole front end not sure if the 2wd fronts can take a shaft if not then u will have to replace the whole front wheel assy. also send vacuum down to actuator and get manual hubs. check cross beam to see if the 2wd and 4wd are different. you might want to see if u can just get a 4wd wrecked one and pull all parts from there
Dash cluster?
landrunner
Aug 5, 2015 09:18 PM
crashburnoveride
Jul 10, 2015 06:39 AM
