Sponsored by: CARiD
charging circuit fuse is blowing
Old Oct 20, 2009 | 06:56 AM
ken o's Avatar
Hello --
I have a 1986 4x4 truck -- 22R engine, 5 spd trans, no A/C, 307,000 miles. Lately it blows the 15 amp fuse marked "ENG" in the under-dash fuse box. I lose the charging circuit ("Charging" light goes on and volt meter shows about 12 volts when running) and the turn signals. If I replace the fuse, even temporarily with a 20 amp fuse, it blows again right away. Could this be an alternator or voltage regulator failure or what? Thanks.
Old Nov 2, 2009 | 09:58 PM
brian2sun's Avatar
You could test your alternator and see what kind of voltage it's putting out, but it sounds like you have a short somewhere.
Old Nov 2, 2009 | 10:29 PM
22RUCRAZY's Avatar
Check and make sure that your grounds are gronded , and check everywhere for cut frayed or lose wires
GOOD LUCK
Old Nov 3, 2009 | 06:15 AM
ken o's Avatar
It did turn out to be a short in the backup light switch. The backup lights and about 5 other circuits are on this same fuse. Thanks.
RyanJ989
11
Apr 7, 2021 09:41 AM
coryc85
Dec 5, 2015 08:42 AM
accuracy
Sep 20, 2015 07:44 PM
Ricu_air
Sep 19, 2015 05:35 AM
Gone Fission
Sep 4, 2015 12:18 PM
