Sponsored by: CARiD
Change gear ratio on dually 1 ton toyo axle??
Old Jul 14, 2017 | 05:57 PM
JLove's Avatar
Hello everyone
I have a 1 ton dually 6 lug Toyota floating axle on a custom truck w larger engine than it was intended for.
Its presently a 4.11 ratio differential..
how do I get it around 3.50 or LOWER??
please, any help would be greatly appreciated.
I need to lower my highway RPM drastically!
Old Jul 15, 2017 | 09:52 AM
dropzone's Avatar
Fossilized
you could swap to taller tires
find a third to swap
http://home.4x4wire.com/erik/diffs/
http://www.brian894x4.com/Gearratiosanddiffs.html
http://www.off-road.com/trucks-4x4/t...ion-18588.html
Old Jul 15, 2017 | 12:27 PM
JLove's Avatar
How to get the different differential size on the SAME axle? Without changing out the Toyota dually. ??
Old Jul 15, 2017 | 01:36 PM
wyoming9's Avatar
Red face
Have you read through those links above??
You remove the differential from the axle housing .
Either have the ring and pinon changed and set up on that differential ( Buy the ring and pinon gears your looking for)
By a complete differential with the gear ratio you seek!!
In both cases Install it back in your axle housing you have now changed you gear ratio.
About as simple as I can explain things
