Sponsored by: CARiD
Carb rebuild
Old Sep 20, 2019 | 07:33 AM
rubronthroad's Avatar
Carb rebuild
I am going to rebuild the carb on my 87, any pointers, do I want to use a rebuild kit or just have one handy?
thanks
Old Sep 22, 2019 | 11:42 AM
old87yota's Avatar
Yes, you will need a rebuild kit. The kits come with all of the gaskets and seals that you will need to replace while doing the rebuild.
Do you have a Factory Repair Manual? There is a great section covering the disassembly and assembly of the carburetor.
Go slow, label parts and bag them, and take lots of pictures as you take things apart.
When I did my carburetor rebuild, I found that many of the screws in my carburetor were very tight and it was easy to strip the heads of the screws. Later I found out that the screws on the factory carburetor are NOT Phillips head screws. They are Japanese Industrial Standard (JIS) cross-head screws that look very similar but have a different profile to the Phillips drive. It is easy to strip out the heads of JIS screws with a Phillips screwdriver.
I would not remove the jets unless you have a tool that fits into them snugly. I damaged one of my jets while using just a large flat-blade screwdriver while trying to remove it.
Here is one of the threads I used as a guide: https://www.yotatech.com/forums/f116...d-time-226236/
Old Sep 23, 2019 | 02:29 PM
Thanks a lot Jake, yes I have a factory repair manual, thanks for the link as well, as far as these custom Phillips screws, can I buy the proper tool somewhere, or just use what I have and be careful?
yotakeith
Feb 2, 2011 07:20 AM
yota7357
Mar 13, 2010 04:12 AM
83
Jan 6, 2009 12:27 PM
toyospearo
Sep 18, 2008 06:45 PM
the_supernerd
Dec 22, 2004 10:25 PM
