Sponsored by: CARiD
Can I swap 16' brake drums from a '07 tacoma onto my '91?
Old May 25, 2011 | 09:09 PM
murt802's Avatar
My '91 4wd pickup needs new rear brake drums- they're worn AND rusty. I have an option on 16'' drums from an '07 Tacoma with only 10'000 miles on them.
Are they compatible?
PS This is my first time working on drum brakes so please forgive any ignorance on my part
Old May 26, 2011 | 05:10 AM
waskillywabbit's Avatar
Perhaps. Drum brakes are pretty cheap to rebuild/replace.
:wabbit2:
Old May 26, 2011 | 05:28 AM
Tofer's Avatar
Sponsor
either buy the correct part or switch to disks... no point in spending time and energy trying to make drum brakes fit on a vehicle that's 16 years older than they are designed for.
Old May 26, 2011 | 07:47 AM
sebastianholmes's Avatar
the point is saving money. wouldnt he need large diameter wheels?
Old May 26, 2011 | 10:40 PM
wyoming9's Avatar
Smile
I would think you would need new backing plates to anchor your new bigger brakes with new hardware and wheel cylinders so your new bigger brake drums fit over.
I have no idea if the axles would need to be changed or not.
But till you get done with time and running around getting the extra parts you forgot you need make it all work
Just buy two new drums you will come out ahead.
Not to mention now having to different size wheels front and back
Old May 27, 2011 | 02:04 PM
BMcEL's Avatar
Rebuild the stock drums unless you are going for increased braking performance, in which case I'd recommend the disc conversion. Drum rebuilds are cheap and easy, just leave one side together for a reference point when reassembling.
Old May 27, 2011 | 02:52 PM
jason191918's Avatar
16' is a HUGE drum. lol sry.
smthwsn357
May 1, 2024 07:28 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
akaphilly
Jul 9, 2015 02:18 PM
AaronM
Jul 8, 2015 07:15 PM
