Sponsored by: CARiD
cab interchange & headlights
Old Mar 3, 2007 | 05:32 AM
troyjmueller's Avatar
I am looking at buying a heavy-duty toyota 2wd truck for a project. It is a 1978 tandem axle motor-home with a shot coach (camper part). My plans are for removing that, and replacing with a flat-bed. My main problem is that the cab for the RV is an open-back, and not suitable w/o modifiction for a pick-up type application.
I have also found a bare 1981 cab.
So, my question is thus: has anyone transplanted (or know of the relevant diferences) a 2nd generation cab onto a 1st generation chassis? year ranges: gen 1 = 1975-1978; gen 2 = 1979 - ~1984.
I have visited my local dealer, and they have helpfully provided parts diagrams, and the frame rails appear the same, with notable differences being the straighter cross-members on the older frame, and differently styled mounting brackets.
(This truck is going to be a ground-up custom re-build. It is needing an engine, hood, fenders, grille, front wheels, etc. I am thinking of going with a 22R/20R Hybrid engine in front of the original (4spd?) manual tranny.)
Headlights: is it fairly simple to upgrade the headlights from the older round-style to the newer square-style design in the 1979-1983 ranges?
Old Mar 3, 2007 | 12:34 PM
4Crawler's Avatar
Headlihgts should just swap over at the connectors, same 3-pin style works on most all high+low sealed beams.
sniper34639
Aug 31, 2015 07:56 AM
bvleonov
Aug 22, 2015 11:39 PM
izzmee
Aug 17, 2015 10:20 AM
landes94
Aug 16, 2015 12:20 PM
mldave
Aug 10, 2015 09:23 AM
