A/C into an 88 EFI???
ok im currently in the middle of adding stock A/C to my 1988 22RE. i read some of 86toyota post about his install on his carb. so far i got the ac core(part under the dash) and some of the lines. As for under the dash everything seems to connect up fine with existing plugs. But is their any missing relays or solenoids like and idle control that are not on the truck becuse of the ac not coming factory in it? also under the dash where is thw wire that connects to the ac compressor i believe it the magnetic signal?
bryan34w
12
Sep 30, 2015 02:50 PM
