Sponsored by: CARiD
buying a new used 91 TOYOTA PICKUP TRUCK
Old Feb 8, 2009 | 08:44 PM
superfast's Avatar
hi NB here.... I'm buying a used 91 4x4 toyota pickup 2.4 4 cylinder engine and it has 227xxx miles on it. truck still runs good with no problem. my question is should replace the head gasket and TC right away? also what else? Oh, also the check engine light is on the guy said it's the o2 sensor. thanks
Old Feb 8, 2009 | 09:57 PM
toyota4x4907's Avatar
Why would you need to replace the HG? If the timing chain has been replaced in the last 150K miles, you're good to go, unless of course it was replaced 150K miles ago.... Also, the timing chain guides are what kills most of these 22res. They either need to be replaced with new plastic ones or metal backed guides, which, from my understanding, should last the entirety of the engine.
Get the exact code and we can probably help you some more.
Old Feb 9, 2009 | 04:45 AM
superfast's Avatar
first of all, thanks for reply.... I'm going to pick the truck up tomorrow and I'll get back to you guys with the code. I don't know and I haven't ask if they guy replace the TC or the TC guides yet.. also it's a 91 how to check for the code? thanks
Old Feb 9, 2009 | 10:43 AM
annoyingrob's Avatar
There's a gray square connector in the engine bay, I believe beside the fuse box, above the battery. Open it up, and stick a paperclip, or small wire between E1 and TE1. Then turn the car on (don't start it), and count the flashes on the CEL.
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
