Sponsored by: CARiD
burning oil, only off camber?
Old Jul 12, 2011 | 03:44 PM
avenged142's Avatar
so the last coulple time i've gone wheelin i have been burning oil on the trail. it seems to only happen after being off camberfor a while and then leveling out or at the end of the trail.
i've been told something about walve seals and also that i might have bad rings. any help is appreciated im ok with mechanics but still learning
thanks
Old Jul 13, 2011 | 02:07 PM
avenged142's Avatar
bumpity
Old Jul 13, 2011 | 04:03 PM
bigarms23's Avatar
check you valve cover gasket it could need to be replaced
Old Jul 13, 2011 | 05:20 PM
toyotaguy68's Avatar
thanks
what color smoke thick white or light foggy blue tint?
when i got my 1st gen p/u it smoked white and the guy i got it from told me the engine was recently rebuilt. i thought yah yah hes just pullin my leg but when i pulled the valve cover you could eat off of it, no joke lol. Come to find out they used crappy valve seals. luckily i was able to pull do it with out pulling the head. but if its blue smoke you need new rings.....
Old Jul 13, 2011 | 05:44 PM
avenged142's Avatar
it looks white in the video. its from my friends phone so idk how to post it. i'll pull my valve cover off later when im working on it. it runs fine otherwise though and my pressure is fine. it has only done it on the trail which is what im confused most about.
thanks for the replies guys
Old Jul 13, 2011 | 06:21 PM
avenged142's Avatar
got the video figured. hope it works.
<iframe width="425" height="349" src="http://www.youtube.com/embed/ufwirxb6rJc?hl=en&fs=1" frameborder="0" allowfullscreen></iframe>
Old Jul 13, 2011 | 07:07 PM
fork's Avatar
wow
i really underestimated how much smoke you meant. give that thing a compression check both dry and wet
Old Jul 13, 2011 | 07:14 PM
mightymouse's Avatar
22r or 22re? carb or fuel injected?
Old Jul 13, 2011 | 07:43 PM
avenged142's Avatar
22re, fuel injected
Old Jul 13, 2011 | 07:50 PM
a compression test will tell you more. That would be the first step to start to diagnose your problem. Pull the plugs and take a look at them while your at it as you're going to do that any ways for the compression test.
Old Jul 13, 2011 | 08:01 PM
xxxtreme22r's Avatar
that looks like water to me. But how is that possible when it's only after and/or during off-camber. Weird. Subscribed as I am curious.
Old Jul 13, 2011 | 08:22 PM
avenged142's Avatar
looks like i'll be doing a compression test after work tomorrow. what would an ideal compression be?
its funny how new i am to this whenn most of my friends built they're rigs from the ground up
Old Jul 15, 2011 | 04:58 PM
avenged142's Avatar
so. compression test results are as follows
#1-175psi
#2-160psi
#3-175psi
#4-175psi
i might have bumped the release valve on the second one. was gonna re-do it but it started raining. these results are also dry. didnt do a wet test yet.
Old Jul 15, 2011 | 09:59 PM
85TurboRunner's Avatar
My old 4runner did the same thing last time I took it out. I have since sold the truck but kept the engine for a new project.
Keep us posted on what you find out.
Old Jul 16, 2011 | 06:22 AM
if that's the case 175 is very very good for a dry test, IIRC it's actually a little more then spec.
Specs are listed in the FSM.
Old Jul 16, 2011 | 08:17 AM
x2 this is odd. Is the "smoke" coming out of the exhaust pipe for sure or could it be something spilling or splashing like the overflow tank from the radiator?
I would almost want to find a steep hill and slowly ramp up it and then down to find out what's going on.
Old Jul 16, 2011 | 01:26 PM
avenged142's Avatar
its for sure comin out the exhaust pipe. first time it happened it filled the whole cab with smoke cause my windows were all down and scared me pretty good.
Blamalam
Mar 12, 2022 07:34 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
TJWilly
Jul 31, 2015 02:05 PM
HookahRoo
Jul 20, 2015 07:06 PM
rushw
Jul 18, 2015 01:46 PM
