Sponsored by: CARiD
Brake line size? 2nd gen 4runner
Old May 23, 2016 | 11:22 AM
mattyboi's Avatar
Is it 3/16"? Just want to confirm that it's right. From searching part stores with my vehicle model this is what I come up with but I find it odd that it's in imperial and not metric.
90' 22re
Old May 23, 2016 | 11:05 PM
wyoming9's Avatar
3/16" is easier then 4.75 mm .
just make sure it has the correct M10x1.0 nuts
Old May 24, 2016 | 07:50 AM
kawazx636's Avatar
MAKE SURE THAT YOU USE M10x1.0 INVERTED FLARE NUTS!!! There is a standard nut (not sure of the size) that WILL thread into M10x1.0 threads but WILL NOT work - you can hardly tell the difference between the two. There is also a M10x1.0 bubble flare nut that looks similar but WILL NOT work either. Napa does have brakelines up to 72" that are pre-flared. Use your original lines as a template to bend new ones and replace a section. I know at Napa they are labeled "JAPANESE" and I'm fairly certain that they don't even have the flarenut sizes on the label.
kawazx636's Avatar
What lines are you trying to replace anyway?
Old May 24, 2016 | 04:30 PM
mattyboi's Avatar
Right side of the tee is leaking. Most likely will have to cut it all out
Badlander
Apr 23, 2018 02:17 PM
4x4-runner
Apr 23, 2018 09:35 AM
layifioren
Nov 14, 2017 03:37 PM
Charchee
May 13, 2017 05:46 PM
etc.
Jun 11, 2016 05:14 AM
