Sponsored by: CARiD
Black Smoke
Old Sep 6, 2007 | 05:27 AM
my4runner's Avatar
Black Smoke
I have notices some black smoke when I start my 4runner in the mornings, 4cylinder 22re...also, there is some splattering of black condensation that comes out of the exaust...this only happens in the morning, any ideas what could be causing this? thanks
Old Sep 6, 2007 | 05:52 AM
PoleVaulter95's Avatar
is this black condesation oil? or dirty water
Old Sep 6, 2007 | 06:04 AM
my4runner's Avatar
Hard to tell, but, you can see it on the ground throughout the day. I had a new cyclinder head installed, had this problem before the new cyclinder, and it still continues. Could it have anything to do with the catalyc converter? Thanks
Old Sep 6, 2007 | 06:13 AM
86toysr5's Avatar
im not a mech. but wat about the rings gettin blowby?
Old Sep 6, 2007 | 06:58 AM
my4runner's Avatar
Could be the rings, the motor has 315000 mile on it, maybe an additive in the oil would help?? What do you think....
Old Sep 6, 2007 | 07:07 AM
04 Rocko Taco's Avatar
oil additive might.....
but snake oils rarely fix a problem....if your rings are getting blowby, the thing to do is drive it till its bad enough to warrant repair (when the cost of the oil you are losing is more than the repair) and then do a rebuild on the bottom end.
Old Sep 6, 2007 | 07:16 AM
my4runner's Avatar
Hope I dont sound dumbfounded, but if it were blowby, wouldnt it be white smoke? This only happens in the morning! Thanks to all that reply!!
Old Sep 6, 2007 | 03:57 PM
FredTJ's Avatar
Generally, not always, but just generally, white smoke either oil being burnt or coolant. Black smoke is, generally, fuel, running too rich.
Fred
Old Sep 7, 2007 | 05:49 AM
my4runner's Avatar
If the possible cause is fuel being too rich, what would cause that to happen? Thanks
Old Sep 7, 2007 | 07:36 AM
mkgarrison5's Avatar
check into running an "auto RX" rinse in your motor.. i am not a big fan of putting anything into a motor other than oil but from what i have read and researched i would deff give it a try.. google auto rx
Old Sep 7, 2007 | 04:21 PM
stormin94's Avatar
Burning rich? Is the check engine light on?
Old Sep 7, 2007 | 05:44 PM
sh0kk86's Avatar
how would you adjust a 22re thats running to rich anyway? is there a fuel mixture screw? like on a carb?
Old Sep 7, 2007 | 09:24 PM
stormin94's Avatar
I highly doubt it. If it is running rich, it may be running hot, or may be running rough, not idling smooth, not reving right, etc. There are any number of things that are signs of running rich, one of the most obvious is black smoke out the tailpipe, and check engine light. Is the check engine light on?
Old Sep 7, 2007 | 10:50 PM
deserttoy84's Avatar
try engine restore in the silver can... that stuff WORKS.
Old Sep 11, 2007 | 12:59 PM
my4runner's Avatar
The check engine light is not on! Thanks
Old Sep 11, 2007 | 03:36 PM
FredTJ's Avatar
Good, pull the codes and let us know what shows up.
Fred
puddlepirate
Jul 30, 2016 06:29 PM
dzldust
7
Oct 6, 2015 05:39 AM
dbollier123
Sep 29, 2015 05:23 PM
whiteyota93
Sep 29, 2015 02:31 PM
charlie_fong
Sep 27, 2015 10:06 PM
