Sponsored by: CARiD
Best grounding spot in engine bay when jumping gen 3 4runner
Old May 2, 2010 | 08:11 PM
pendrag's Avatar
Where do you like to ground out your negative jumper when jumping off a gen 3 runner?
Old May 2, 2010 | 09:02 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The negative terminal won't kill you and cause the mattress police to come looking for you... And a ground's a ground...
Otherwise, look for something with some meat on it, like you'd use as a ground.
Just look for aluminum or rubber behind it as it won't be as good...
Old May 2, 2010 | 09:31 PM
pendrag's Avatar
I just don't want to fry something or blow up the battery...Human sacrifice, dogs and cats living together... mass hysteria.
Old May 2, 2010 | 09:48 PM
theMonch's Avatar
Yeah, negative terminal on the battery. I never really understood why or who first told me years ago to put it somewhere else, but I never could figure out why? The neg terminal attaches directly to the block on every vehicle I have worked on. I have jumped hundreds of cars this way for years and have never had a problem.
Old May 2, 2010 | 09:54 PM
Elton's Avatar
i also go off the neg terminal that and i added 2 more 4ga grounds
Old May 2, 2010 | 11:31 PM
wyoming9's Avatar
Red face
The grounding of the jumper cable to other then the negative battery terminal is a hold over from the old days.
To prevent an arc which could ignite the hydrogen gases vented by the battery in the days batteries had vents and removeable caps
Old May 2, 2010 | 11:37 PM
theMonch's Avatar
Ahhh. very logical. I'll put that on the list of things I learned today. : )
Old May 3, 2010 | 07:50 AM
myyota's Avatar
Ive always just hooked the jumper cables to the battery, and ive never had any problems doing it that way.
Team420
Jan 12, 2021 04:57 PM
live4soccer7
Sep 3, 2015 12:29 PM
WI Girl
Jun 25, 2015 03:45 AM
2wdtundra
Jun 18, 2015 05:19 AM
westbound
Jun 7, 2002 03:30 PM
