Sponsored by: CARiD
BAD hesitation/ power loss/ gas mileage - no check engine light/codes
Old Feb 28, 2022 | 06:24 PM
  #61
crawe01's Avatar
Originally Posted by Jofreidr
yes, fuel filter. its there for a reason and can cause troubles exactly like these when it starts to get old/plugged
e\ surprised it took someone *4* years to come up with that.
Thank you for your input. I have replaced the fuel filter twice.
Unfortunately, I found the correction to the problem. While being lazy, I used a spray to clean the intake valves since cylinder 4 was not firing. I subsequently, seized the block as I could not maintain enough engine speed to keep sufficient oil flow enough to balance engine stutter; THE ENGINE IS NOW SEIZED at cylinder 1 on the crankshaft.
Upon removing the rocker arm assembly and camshaft, I noticed the camshaft was worn so badly, each lobe had a 1/2 inch blade from wear from the rocker arms. The engine should not have been running at all.
Old Feb 10, 2023 | 04:57 PM
  #62
Darius's Avatar
I dont know kinda sounds like a plugged catalytic converter
Justin's Fly
42
Feb 10, 2023 05:02 PM
kaiowa99
Mar 29, 2011 04:33 AM
MB4runner
50
Feb 16, 2011 07:00 AM
artinge3
Apr 20, 2008 05:41 PM
berlybelle
Sep 2, 2003 05:20 AM
