Sponsored by: CARiD
Bad Gas Milege
Old Nov 19, 2006 | 12:59 PM
rebootej's Avatar
Bad Gas Milege
I am an 18 year old, who recently bought a 95' 3.0, 140,000 mile 4 wheel drive Toyota pickup. I was getting roughly 250 miles per tank, I decided to change out the plugs and install new wires. I had a problem with one of the plugs- it was frozen and very hard to remove. I didn't like the way the new plug felt going in so I used a thread chaser on it to clean up the threads. The plug went in fine after that. Once I had it all back together, my milage per tank dropped down to about 225 miles and I'm not sure why. The truck runs well. Any ideas what I might check? I have some of experience and my dad can help me out. Thanks
Old Nov 19, 2006 | 01:28 PM
Paul H.'s Avatar
Welcome, were the plugs gapped correctly and are your wires all seated. Did you change your air filter? Try putting some injector cleaner in your tank. may help. By the way, 250 is about normal for the 3.0. How many tanks did you get the 225 with. If you got 225 after several tanks then somewhere there is a problem.
Old Nov 19, 2006 | 06:40 PM
tc's Avatar
tc
Tire air pressure has the biggest effect, and cold weather affects it pretty dramatically. I would check that first...
Old Nov 19, 2006 | 07:14 PM
BigBen's Avatar
wow well i just recently bought a 91 pickup 3.slow and i get 225 miles per gallon....but last time i changed my spark plugs i found out one of the dumb asses at where ever the spark plugs were changed had cross-threaded it...so i had to try to manually re-bore the hole....
Old Nov 20, 2006 | 07:16 AM
eric-the-red's Avatar
What brand of plugs and wires did you use. Toyota engines don't seem to like anything except NGK or Denso plugs, and OEM wires.
Old Nov 20, 2006 | 08:58 AM
91TPU's Avatar
mine seems to love my ngk wires, and really loves my NGK Plat G power plugs, since i pulled autolites out of it, needless to say, i was pissed that someone used cheapos
Old Nov 20, 2006 | 09:15 AM
HUTCHSTACO's Avatar
I wish i could get 225 mile per gallon
Old Nov 20, 2006 | 09:26 AM
Stevo3's Avatar
x2 that would be great
Old Nov 30, 2006 | 05:58 PM
traben27's Avatar
haha im pretty sure he meant per tank...i know him personally...sometimes he gets a little confused lol.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
