Sponsored by: CARiD
antifreeze in oil
Old Oct 24, 2010 | 05:33 PM
4runnasr5's Avatar
antifreeze in oil
i have a 98 6 cylinder 4 runner and i have antifreeze in my oil but it dont get hot. anybody had this problem or can anybody tell me whats wrong
Old Oct 24, 2010 | 05:51 PM
myyota's Avatar
Blown head gasket or cracked head.
Old Oct 26, 2010 | 11:15 AM
Skibjork's Avatar
Compression check it and that'll tell you if the head is OK. If compression is good check the timing chain and cover as well. Could be that the chain is cutting into the aluminum and opened up a hole for the pump to leak that coolant in.
I'm working on the same issue right now with my '87 4Runner
Old Oct 26, 2010 | 11:48 AM
fork's Avatar
^this
a 3.4 has an aluminum cover and chain? x2 on compression or leakdown test. i'd put my money on head gasket
im also fixing the same 22r-e timing cover nonsense on my '88 :| the cover looked fine and the tracks werent too deep, so i reused it. oops. pinhole leak
Old Oct 26, 2010 | 12:09 PM
Skibjork's Avatar
Fork, good point, haha wasn't thinking.
As for my '87 the cuts are pretty deep and I lose all my water into the engine within hours of it being full. Compression was great on mine and that's what led me to look into the chain issue and find the cuts. I'm trying to get the timing chain cover off currently to get a better look.
Is there a way to get the cover off without removing the cylinder head and without destroying the head gasket or I'm I dreaming too big?
Old Oct 26, 2010 | 05:21 PM
fork's Avatar
as a matter of fact,
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
calderp
Jul 27, 2015 09:58 AM
kcaudill
Jul 20, 2015 12:06 PM
Jonny246
Jul 12, 2015 04:51 AM
