Sponsored by: CARiD
Always P/S fluid instead of ATF??
Old Dec 31, 2009 | 08:18 AM
4Crawler's Avatar
Originally Posted by mmcpeck
Wow, sounds like there is no need for P/S fluid to even exist then. Why would you ever need to use P/S fluid if ATF is so much better for the system, and P/S fluid has nonce of hese thing in it? Why is it even sold anymore?
There are P/S systems that can use DOT 3 brake fluid's though right?
All depends on what the system was designed to use. If all the components were designed to work with PSF, then that is what you need to use in it. If it was designed for ATF, then that is what you need to use.
Same way that some manual transmissions and transfer cases are designed to work with gear oil, while others work with ATF.
ladybugRC
458
Aug 21, 2020 10:41 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
gentry
Sep 28, 2015 06:16 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
