altitude adjustment needed??
Hello all, newbie here. Last week I purchased a 2016 Rav 4 LE in Denver, Colorado and drove it to my home in NH. Is there anything I need to do as far as corrections for the difference in altitude 6000 feet in Denver to 300 feet in NH? It seems to run fine. The other issue is a check engine lite, took it to a local general shop, codes said evap, had the canister assy replaced (pretty pricey) worked for a day and the darned light is on again. Going to return it to the shop for a re-look Monday. Any suggestions as to either question? Thanks a lot in advance...
Interesting topic!
My 22RE does OK in low altitude but going up same grade slopes in high altitude, I could only do around 50 in 3rd gear or 55 in 4th. I suspect it must be the thinner air - less oxygen in a given volume of air.
I am not aware of any sensor the ECU uses to sense altitude.
Thank you for the info, wicked smart 'puters right? It is in the shop today for evaluation on the engine lite, have a great day!!!!
Interesting topic!
blackdog314
Feb 5, 2012 07:43 AM
xtinex
7
Nov 29, 2005 02:45 PM
Traumahawk
Nov 4, 2005 06:54 AM
