Sponsored by: CARiD
Airing down without losing a bead
Old Sep 9, 2007 | 11:56 PM
stormin94's Avatar
10-15 should be fine for most anything. If in doubt, keep it a little higher than that. I've put tires on rims before, and taken them off. It takes quite a bit of force to get a tire off bead. Just remember to take her easy when you got the tires aired down. It helps to have a spare just in case...
Old Sep 10, 2007 | 04:59 PM
hodgepodge79's Avatar
Originally Posted by Shoua
So I went out today. I aired them down to 12 psi. I some pretty gruesome (well, to me anyway) lines up a half-sand covered hill, and never lost a bead, although a Cherokee with 33's and lockers front and rear made it look too easy. I had to take the lines usually a few times to make it, but made it (no lockers!). I'm guessing I could have went down to 10 psi, even possibly 8, but as this was my first time airing down my tires, I did not want to risk it. But the aired down tires made a HUGE difference in grip, especially off-road.
Terrain will be a big deciding factor. soft sand or snow will allow for lower psi levels (7-10). Rocks and hard pack, keep it in the -teens.
Old Sep 10, 2007 | 05:13 PM
4Mogger's Avatar
Keep in mind that airing down also allows the tire to spin on the wheel. This causes severe misalignment of the balancing weights and will result in rapid tire wear once you air up and hit the pavement.
Most people are unaware of this having occurred but it is easy enough to test on your rig....just chalk the tire to the rim and go wheel. You will find that the chalk line has moved significantly from the mark on the wheel.
You then have 2 choices:
1. Re-balance your tires after every wheeling trip BEFORE you put any highway or pavement miles on the tires or...
2. Pull off those static balancing weights and install the appropriate amount of a product such as Equal tire balancing beads. They dynamically balance the tire at all speeds and safe operating pressures. You will also need to install filtering valve stems to filter the media from the air as you air down.
Old Sep 10, 2007 | 05:19 PM
4Mogger's Avatar
Originally Posted by colsoncj
something that no one has mentioned, or i missed it, is for those who DD thier rigs, popping a bead isnt the only thing to be concerned about. When you lower your tire pressure you also increase the risk of the tire spinning on the rim, thus changing your wheel balance. Its always a good idea for those who DD thier rigs to use chalk and mark a line that crosses rim and tire to see if you've spun it if you air down real low.
back to topic, id say around 15 safely for your combo... I run between 7 and 15 with 33x12.50 on an 8" rim, and could probably go less if needed. But, like many have said, it will depend on setup, driver, and conditions.
nevermind my post above.
MO transplant
Apr 23, 2023 11:58 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
ManzDaKlown24
Aug 22, 2015 10:25 PM
ia02
Aug 20, 2015 11:04 AM
Toyvana
Jul 29, 2015 10:47 PM
