Sponsored by: CARiD
94 v6 pcv valve?
Old Jan 19, 2007 | 03:00 PM
jbridered's Avatar
94 v6 pcv valve?
How important is it to change the pcv valve? I found mine but it seems real hard to get to. I also noticed my intake hose had melted which left a big hole. I have a problem overheating on the interstate after doing 70 for about 10 minutes. Changed water pump head gasket and thermostat. Radiator bypass hose along the firewall gets hot really fast and i had to change it because it busted. It now burns more gas and has less power. I also did away with cat converter. I hope its a radiator problem and maybe some o2 sensors.
Old Jan 19, 2007 | 03:10 PM
keithguts's Avatar
I can tell you that the PCV Valve is not your problem.................
Old Jan 19, 2007 | 03:12 PM
Paul H.'s Avatar
I would check all of the vacuum hoses and change the pcv and check the hose fro that too. And why did you get rid of the cat. That is illegal you know and since you have an O2 sensor before and after cat I believe. That could be your problem.
Old Jan 19, 2007 | 03:34 PM
Bigblock's Avatar
Your probly running lean or rich without the cat causing you to run hot.
Old Jan 19, 2007 | 03:39 PM
jbridered's Avatar
yeah i think i will get a whole new exhaust. If its a head gasket problem i will just have to sell the truck.
LotOMiles
Sep 14, 2015 11:45 PM
ac7822
Sep 11, 2015 08:49 AM
Boomer8404
Sep 10, 2015 09:01 AM
idadan208
Sep 7, 2015 09:06 AM
