Sponsored by: CARiD
94 truck 22re, temp gauge not working? new owner
Old Feb 23, 2012 | 06:44 PM
spike0001's Avatar
I just bought a 94 4x4 truck. it is all stock, 22re. temp gauge is not working and the truck idles at 1200 hot or cold. I put a new thermostat in today and found out it did not have a stat in. still same problem with gauge and idle. can someone please help?
Old Feb 23, 2012 | 06:49 PM
TylerH's Avatar
Make sure you give it time to get warm. Did you burp your coolant system?
Old Feb 23, 2012 | 06:57 PM
spike0001's Avatar
drove 10 miles, not working, yes I burped her
Old Feb 24, 2012 | 06:04 PM
TylerH's Avatar
Ground the sensor throu a test light or something that has resitance. That will tell you if your wiring is good. Once grounded it should raise to the H really fast.
Old Feb 27, 2012 | 07:44 PM
spike0001's Avatar
it was the sensor, put a new one in and temp gauge works. I did a full tune up, turns out timing was way off, and now the truck run's great. thanks for your help TylerH
the1998sr5
Oct 19, 2016 12:48 PM
Eagle564
Jun 23, 2015 11:29 PM
Robinhood150
Jun 1, 2002 08:07 PM
