Sponsored by: CARiD
93 toyota t100 starting problems
Old Jun 15, 2012 | 06:26 PM
Blacksmith's Avatar
Working on a 93 toyota t100 with a v6 3.0 liter. It wont spark replaced cap, rotor, plugs, wires, coil, and igniter still wont spark. What do u suggest??
Old Jun 15, 2012 | 06:33 PM
rworegon's Avatar
EFI/ECU/Engine Fuse?
Old Jun 15, 2012 | 06:36 PM
Blacksmith's Avatar
Also tested those
Old Jun 15, 2012 | 07:05 PM
rworegon's Avatar
Timing belt slip? Loose ground(s)? Battery charge ok? Circuit Opening Relay (COR) failed? Any work done prior to problem starting?
If you haven't already, take a look at the FSM that most closely matches your rig from the ling in my sig line. The diagnostic section....
Old Jun 15, 2012 | 07:46 PM
Blacksmith's Avatar
Grounds are good, i will check the rest now
Old Jun 15, 2012 | 09:22 PM
Blacksmith's Avatar
Alright tried all that above still nothin
Old Jun 16, 2012 | 05:05 AM
93toyrunner2's Avatar
Test wiring at the ECM. See page 3 of this pdf:
http://www.ncttora.com/fsm/1990-1995...e/troubles.pdf
Old Jul 15, 2012 | 06:53 AM
92_yota_v6's Avatar
blacksmith, did you ever find out what was causing this? mines doing the same thing and we can't find out what it is
Crazychris1871
Jun 27, 2016 10:38 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
bigblue82
10
Jul 6, 2015 08:27 AM
streetuner15
Jun 18, 2015 10:59 PM
