Sponsored by: CARiD
92 manual hubs
Old Jan 16, 2010 | 07:54 PM
bowzerdoo77's Avatar
92 manual hubs
i have a 92 4x4 and its a bitch to turn the hubs. do they just need to be greased or do i need to replace them? if so any good ones to get..
Old Jan 16, 2010 | 08:01 PM
iamsuperbleeder's Avatar
the dial O-ring is probably old and worn out on it
best bet would be to get the seals from a dealership (like $10 per side; not too bad), and rebiuld them yourself
use the search button near the top-right and you can find some info on rebuilding them
and I, as well as everyone esle, will advise you to keep and rebuild your OEM Aisin hubs instead of going out and buying Warn's or something instead...
also, just FYI, watch the language in the forums; this is a family/work safe forum, so keep that in mind in the future
Welcome to YotaTech!
Old Aug 7, 2010 | 11:36 AM
4x4jeffyota's Avatar
i have a question, i need to rebuild one of my hubs, to take it off can the tire still be on the ground or does it need to be in the are? thanks Jeff
Old Aug 7, 2010 | 11:41 AM
certainly, you can remove the hubs with the tire still on and the truck's weight on it, it just might be a little more of a pain to work with
Old Aug 7, 2010 | 01:33 PM
pruney81's Avatar
I'd probably jack it up before I started messing with the hubs. Personal preference I suppose.
Old Aug 7, 2010 | 04:35 PM
ok, thanks man
carlspeed
Aug 23, 2015 02:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
