Sponsored by: CARiD
90 4Runner ck engine Light
Old Oct 31, 2007 | 03:23 PM
BMJ's Avatar
BMJ
Just took the old dog in to get the valves adjusted and for the tech to ck the reason why the ck engine light is on. The codes read EGR and Knock sensor.
He had a new knock sensor, installed it, reset the computer after the valve adjust. EGR went away but the knock sensor code still comes up and the light is still on? He ckd the wiring and all is ok so now he is thinking faulty computer??
Any ideas from the Guru's here? Otherwise runs ok. He advanced the timing just a bit so, not undrivable at all.
Thanks for any help/advice
Bryan
1990 4Runner 4x4 3.0L
1998 4runner 4x4 3.6L supercharged
Old Oct 31, 2007 | 03:52 PM
GSGALLANT's Avatar
You replace the knock sensor wire? It typically gets brittle from the heat and can break inside the insulation.
Old Oct 31, 2007 | 05:01 PM
BMJ's Avatar
BMJ
Yes, the wire was changed also. Has the tech and myself stumped?
Thanks for the input
Bryan
Old Nov 2, 2007 | 07:41 PM
BMJ's Avatar
BMJ
Have another problem now, more often than not, if you hold the throttle at 1500 rpm, it will surge to 1800 rpm then back to 1500 rpm and continue to oscillate!! Does not do it above or below this. Sounds/feels like it has gas to 1800rpm then cuts out till hits 1500rpm over and over?
Anyone else with this? I'm thinking computer?
Bryan
Old Nov 2, 2007 | 07:44 PM
rowdy235's Avatar
Run some seafoam through the system before doing anything else. I'm not sure if adding it to your gas or adding it through the pcv would yield better results. If it was me, I'd run like a third of the can through the pcv, let it sit for 15 min, pour the rest in the tank, then run it til the smoke stops.
Old Nov 3, 2007 | 07:00 PM
BMJ's Avatar
BMJ
Did the Seafoam this afternoon. Runner idles even better now. Smoke was outrageous!! I'm sure the neighbors must of thought the house was on fire for a few minutes! Runs fine except for the darn ck engine light(knock sensor) and the surging at the mentioned RPM's. Anything below or above, engine runs great. Has me leaning towards the computer from reading other posts?
Bryan
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
