Sponsored by: CARiD
89 toyota 4x4 22-re wont start after oil pan pull and clean. help!!
Old Aug 12, 2013 | 08:11 AM
TheEastBeaster's Avatar
hello, i have an 89 toyota 4x4 pickup (22-re) 130k that i bought a few months back. always ran and started good. the truck then sat for 3 weeks without me starting it. Yesterday i took off the steering column and unbolted the oil pan. It still didnt come off so i just unscrewed the 4 bolts holding the oil pan filter, took it out and wiped it down, (the screen was a little clogged so i fixed that too.) I then cleaned out all the little plastic timing guides out of the bottom of the pan by hand. I then bolted the oil pan filter back in. put sealant around the pan and put the oil pan back on. Waited an hour, then added new oil and filter (4.5 quarts). no leaks. Next i took the battery off the trickle charger (it had full charge) and installed it. Turned the key..... and nothing. only the key buzzer goes off. It doesn't even want to try and start. I just cant believe it. i didnt starve the engine of oil. what the heck happened? I looked around and havent seen anything like my problem....please any input or trouble shooting guides would be greatly appreciated.
Old Aug 12, 2013 | 01:50 PM
wyoming9's Avatar
Red face
Sounds like your battery terminals are not on correct
When you removed the cables did you short anything??
terminals clean and tight not broken.
You did not knock the wire off the starter solenoid in moving around under the truck??
That or something at the battery.
Old Aug 13, 2013 | 06:52 AM
It was the cable running to the starter. it was corroded and a little loose on the solenoid. I probably smacked it yesterday while doing something and that was the last straw. cleaned the terminals and plugged it back in, cranks right up. whew. thank you for your help and ideas, im in no way considered a mechanic, so i panic easily. here's to the first of many stupid mistakes. haha
Old Aug 13, 2013 | 10:05 AM
wyoming9's Avatar
Red face
As long as you learn from your mistakes.
Try not to panic just think things out
It is all a learning experience .
Welcome!!
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
gog1968
Jun 22, 2015 05:55 AM
Corey
24
Jul 15, 2002 07:53 PM
