Sponsored by: CARiD
89 4runner need help
Old Jan 16, 2011 | 03:55 PM
cwillis's Avatar
I just did i timing chain replacement on my 89 4runner, 22re.
buttoning her back up i have coolant draining out of the oil pan. I filled the coolant before i put the drain pan plug in and heard it.
The valve cover didnt have ANY wear on it. so i know there is no hole from chain wear.
New timing cover gaskets, new water pump, all new seals.
wtf?!
i replaced it because it has been missing when cold. When i pulled the valve cover, there was slack in the drivers side of the chain.
I assumed that the tensioner has been worn out, or stuck, and/or the chain was streched. i replaced it all just in case.
The chain guides had VERY little wear on them. The tensioner had some decent grooves in it.
I made sure the gaskets were sealing around the passages, and added some FIPG to be sure.
reassembled, and added water. leaking through oil pan. WTF????
also, this leak is intense. more like a major loss of fluid. if i tried to start it, it would be catastrophic. help!!!!
Old Jan 16, 2011 | 04:15 PM
Teuf's Avatar
Looks like your taking it apart again, that stinks. I have never done mine, knock on wood.
Old Jan 16, 2011 | 04:43 PM
xxxtreme22r's Avatar
very stupid question, but are you sure you added the coolant to the top of the radiator and not the oil cap?
Old Jan 16, 2011 | 04:50 PM
streetlancer's Avatar
^Thats funny...
Old Jan 16, 2011 | 04:52 PM
Originally Posted by streetlancer
^Thats funny...
but very possible.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
