Sponsored by: CARiD
63" chevy spring swap
Old Oct 23, 2007 | 01:46 PM
4x4YOTA's Avatar
I want to swap in some 63" chevies on my 94 pick up xtra cab and want to know how much lift it will give me and what all do I need to modify other than mounts (spring/shackle hanger & shock)... if you have any pics of ride height of your 89-95 xtra cab with 63" chevies and set up pics too thanks
Old Oct 23, 2007 | 01:53 PM
LTrunner's Avatar
depending on the srpings will will get 2-3.5 inches of lift.
you will need;
the swap kit from sky's http://www.sky-manufacturing.com/welcome.htm
if you wanna relocate your your shocks they also have the shock it and the u-blot flip kit
springs from a 90-98? chevy 1500, either 2wd or 4wd( 2wd are softer and have 3leafs, 4wd are a little stiffer and have 4leafs)
before...with a AAL on stock size tires
after, with a truck full of poeple on 33s
some flex shoots
Old Oct 23, 2007 | 01:55 PM
4x4YOTA's Avatar
you will need;
so to get the lesser amount of lift i and a better ride I should use the 2wd leafs
Old Oct 23, 2007 | 02:09 PM
LTrunner's Avatar
kind of... the lift will depend the arch thats left in the springs when you get them, it's just the 2wd springs are softer and give a nicer ride
Old Oct 23, 2007 | 04:04 PM
4x4YOTA's Avatar
so ether way you rcomend the 2wd leafs...
Old Oct 24, 2007 | 12:21 PM
4x4YOTA's Avatar
any one have pics of a 89-95 xtra cab with 63" chevies
Old Apr 7, 2008 | 07:37 PM
4x4YOTA's Avatar
Bump...
Flying91
45
Apr 11, 2024 04:39 PM
boogiewoogie
Jul 24, 2015 05:10 AM
yourrealdad
Jul 21, 2015 11:13 AM
wilbertd
Jul 6, 2015 07:39 AM
