Sponsored by: CARiD
3vze New longblock installed, not firing
Old Sep 9, 2018 | 01:02 PM
opie6837's Avatar
I just installed a new longblock in my 1994 sr5 automatic v6 4x4. Engine won’t start. I’ve triple checked the timing. Just not firing. Any suggestions?
Old Sep 9, 2018 | 07:07 PM
Co_94_PU's Avatar
Gasoline internal combustion engines require, spark, fuel, and compression all at the correct times. Which have you verified, and how did you verify each requirement?
Old Sep 10, 2018 | 04:40 AM
opie6837's Avatar
I checked fuel at the last banjo bolt on the fuel rail. I checked #1 spark plug with the plug out and grounded against the motor. No spark when I turn the engine over. I ohmed all the components the manual said to check. All check within range.
Old Sep 10, 2018 | 07:22 AM
Co_94_PU's Avatar
No spark..
Pull the distributor cap, check for a rotor, and that it turns when the key is bumped momentarily to start.
Yes it's happened before, people forgetting the rotor.
Verify fuses intact, in place, and not partially blown.
Check for injection pulses at the ecu with test light.
Proceed with Sensor test, then ignitor and coil. Ensure all plugs are firm and clean. Manually fire the ignitor and coil.
One of those is likely bad.
xylicon
Jul 21, 2011 10:53 AM
spary_57
Feb 8, 2011 09:27 AM
bcumbie
Mar 9, 2008 06:08 PM
mikemaness
Feb 24, 2004 08:39 AM
