Sponsored by: CARiD
3.4 ticking sound
Old Dec 31, 2009 | 01:08 PM
toyotabruce's Avatar
3.4 ticking sound
hey guys looking for some help. i have a ticking sound in my motor sounds like from under the valve cover. goes away when the rpms go up /oil pressure. maybe looking for some clues before i take it in or rip it apart
Old Dec 31, 2009 | 03:43 PM
brian2sun's Avatar
Toyotas tick. Unless it really load, it's normal. Find another yota w/ a 3.4 and compare yours to it. I'll bet it's nothing out of the ordinary.
Old Jan 1, 2010 | 11:58 AM
its loud. with window down i can really hear it. i had a 3.4 in a tacoma before and it wasnt anything like this
Old Jan 1, 2010 | 12:20 PM
brian2sun's Avatar
Ok, had to check (a lot of people think the normal ticking is a problem). Sounds like you may have an exhaust leak at the maifold.
Old Jan 3, 2010 | 07:16 PM
thanx ill check it out. could it be a lifter or rocker or something. it seems to do it when the oil pressure is all the way down
Old Jan 3, 2010 | 07:36 PM
Kiroshu's Avatar
Theres no rockers in a 3.4. What do you mean oil pressure all the way down? ITs not getting too low is it? Check your oil? Got oil? May be time for an oil change. Could be a possible exhaust leak seeing as how i have not heard the sound in person guessing is wide open turf here. So you mean you can only here it at idle. I would not worry about it unless its causing driveablity issues.
Old Jun 11, 2010 | 06:11 PM
Epcofabrication's Avatar
Did you ever find out what it was? My 99 just developed an interesting ticking noise at 700RPM's and goes a way at 900+ RPM's, sounds the loudest from under the back of the motor. Thought it was the Evap clicking but it sounds more mechanical.
Thanks
Tony
*Edit* My noise ended up being the flex plate. It was cracked in 5 places, I caught it in the nick of time.
pplusent
Sep 18, 2018 10:02 PM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
coleypull15
Nov 3, 2015 07:41 AM
Sidherish
Aug 2, 2015 01:42 PM
cars-guy
Jul 11, 2015 07:51 PM
