Sponsored by: CARiD
3.0 Help
Old Dec 17, 2006 | 08:43 AM
89XTRA's Avatar
3.0 Help
Hey everyone, i just bought an 89 XtraCab with the 3.0. The truck starts up fine but it has little power and and runs very rough after that. I'm thinking that it might be the 02 sensor/fuel filter/clogged cat?? It has 154,xxx miles on it. I just wanted to see what you guys had to say about it and see if i'm looking in the right direction. Thanks for all your help in advance.
Old Dec 17, 2006 | 09:49 AM
tc's Avatar
tc
Start with the easy stuff - timing, plugs, wires, cap, rotor. I have had good results from Seafoam in making mine run smoother. If you don't know the previous owner or get maintenance records, I would do all that plus change all the fluids just to know where you're starting from.
NOTE: Do NOT use Bosch plugs or wires. Only NGK or Denso.
Are you getting a CEL? (Note: bad O2 sensor doesn't always throw a CEL)
This may help:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Dec 17, 2006 | 09:57 AM
89XTRA's Avatar
The prevoius owner just replaced the plugs, wires, and cap before i bought it.
Yes i am getting a CEL
Old Dec 17, 2006 | 10:01 AM
tc's Avatar
tc
The FSM gives the procedure for shorting the diagnostic plug under the hood and reading the codes.
Old Dec 17, 2006 | 10:08 AM
89XTRA's Avatar
Thanks for the helpful link tc
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
