Sponsored by: CARiD
3.0 to 3.4 swap expertise needed
Old Nov 7, 2014 | 04:13 PM
Alex904r's Avatar
Was offered a 3.4 4runner engine (was not sure of year but 2001 or newer), to replace my 3.0, on (89 4runner.
Q: What are the year limits on these type of swaps? Will ANY 3.4 work on my 89 4runner?
Appreciate your experience and wisdom.
Old Nov 7, 2014 | 04:42 PM
wyoming9's Avatar
Red face
Yes to a degree the ones with the throttle by wire can be a little more interesting.
You really want to know the year and vin of the vehicle the engine came from it can make things so much easier .
Read over the 3.4 swap section quite a bit good bit information to be had.
Old Nov 15, 2014 | 02:19 PM
Alex904r's Avatar
Hey,
My current problem (does not stay running) 3.0 continues to get elusive.
Here is the latest:
What I have done is, replaced fuel pump->replaced fuel felter-->checked injectors (are good)-->checked (and found to be good) TPS-->MPS.
Today.
Checked resitance of pickup coils and got 153.4, which is between 140 and 180. Motor still runs but shuts off in about 30 seconds.
Any ideas?
Old Nov 15, 2014 | 02:42 PM
wyoming9's Avatar
Red face
Check to see if your circuit opening relay is working like it should
Old Nov 15, 2014 | 02:50 PM
Alex904r's Avatar
Okay, thanks.
But, this term is new to me. Sorry. "circuit opening relay"? Would you share more details? What it is and how to check it.
I only have a manual that does not explain any of these details.
Alex
Old Nov 15, 2014 | 05:30 PM
Thehollywood811's Avatar
I went through many many problems with my 3.0.... have you replaced the basic tuneup items? Plugs wires cap rotor? Check plug condition?
Old Nov 15, 2014 | 05:31 PM
Also have you checked for any codes?
Old Nov 15, 2014 | 08:08 PM
Alex904r's Avatar
89 4Runner, 3.0, will not stay running
THanks for the reply, guys.
Yes. It has new plug cables, rotor, plugs. Still runs perfectly about half a minute and dies. For some reason, sometimes it has not spark...Mystery. Have checked the coild and igniter as well...Driv
ing me crazy!
Old Nov 15, 2014 | 08:09 PM
Alex904r's Avatar
Oh, I forgot. No. I have not checked for codes but will tomorrow.
Old Nov 15, 2014 | 08:18 PM
Hmm that's weird, positive your egr isint sticking? And do you know your plug gap?
Old Nov 16, 2014 | 07:43 AM
Alex904r's Avatar
EGR, Plugs gap
Not sure about EGR. Will check that as well.
Gap on plugs is fine, according to specs.
Yes. It is weird.
Old Nov 17, 2014 | 08:14 PM
vital22re's Avatar
totally a bro
If the air flow meter is not working/ hooked up, it will not send the signal to the Circuit opening relay to turn on the fuel pump. If you pop the hood, and jumper the FP and B+ terminals in the little grey box on the motor labeled as diagnostic it will hot wire the fuel pump to stay on. It sounds like its getting the STA *start* signal to the COR to prime the system, but the relay isn't getting the *running* signal to keep the fuel pump going.
Old Nov 17, 2014 | 08:18 PM
If his afm isint working/not plugged in I don't think it would even start and idle up. At least mine won't...
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
94whiterunner
Sep 22, 2015 07:25 PM
Edionne13
Jun 21, 2015 11:37 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
