Sponsored by: CARiD
22rte 4runner runs no power help??
Old Jan 27, 2011 | 01:34 PM
84sdyota's Avatar
I bought a 86 22rte 4runner with the head off for $700 bought head gasket set put i got it all back together it has good compression new plugs no leaks timings good tps is good but have almost no power it drives but barely any suggestions? anyone in san diego who would have time to check it out? I usualy work on chevy's so i dont know to much about yotas.
Old Jan 27, 2011 | 05:38 PM
DeathSycthe02's Avatar
whats the compression? hows the turbo, what turbo is on it does it still have the factory ct-20?
Old Jan 27, 2011 | 05:50 PM
84sdyota's Avatar
yeah it still has the ct-20 the turbo is good not loos no cracks the compression is 120 across.
Old Jan 27, 2011 | 06:06 PM
the 22ret is suppost to have 149psi compression
Old Jan 27, 2011 | 06:09 PM
84sdyota's Avatar
is that when the turbo boosts
Old Jan 27, 2011 | 06:42 PM
Swimmerboy2112's Avatar
How about your clutch? Maybe its slipping.
Old Jan 27, 2011 | 07:43 PM
84sdyota's Avatar
Clutch is good not slipping floor it and it doesn't rev up I can move it bit it has no torque to it
Old Jan 27, 2011 | 09:19 PM
olharleyman's Avatar
if it has them check your cat and O2 sensors they same to have a huge effect on the way a 22 runs
Old Jan 28, 2011 | 04:46 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
...RTE 4Runners didn't come with a clutch.
So now you've got to worry about what kinda rigged Toyota ya got, and how it was rigged...
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
Robinhood150
May 29, 2002 06:05 AM
