Sponsored by: CARiD
22RET question
Old Nov 10, 2011 | 04:23 PM
kenichols29's Avatar
22RET question
What should the compression be for a 22rte? My dad is getting ready to go buy one and he is going to check the compression on it before he buys it.
Old Nov 10, 2011 | 04:30 PM
paintthetown's Avatar
149 psi
Minimum pressure 120 psi
Good Luck
BTW it's 22RTE
Old Nov 10, 2011 | 04:45 PM
Originally Posted by paintthetown
149 psi
Good Luck
BTW it's 22RTE
Thanks. Is there anything else we should be looking for to tell if it is in good or bad shape other thank compression?
Old Nov 11, 2011 | 05:01 AM
Is this your first Toyota?
Old Nov 11, 2011 | 07:01 AM
No. I own one, which is my first. My dad is buying this to drive back an forth to work. He's owned 3 or 4 toyota pickups without turbos, this is his first toyota with a turbo.
Old Nov 11, 2011 | 07:31 AM
B874Runner's Avatar
make sure the turbo is in good shape. If not you will be spending quite a bit of cash to fix or replace it.
Old Nov 11, 2011 | 07:46 AM
From what I hear the turbo is in good shape.
Old Nov 18, 2011 | 10:49 AM
Tiyoda87's Avatar
For a Turbo to be in good shape it just needs to be able to have a free spin and good seals right?
Old Dec 2, 2011 | 04:38 PM
B874Runner's Avatar
if the exhaust housing is cracked due to poor cooling. which is the most common problem on the CT-20 its a paperweight.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
