Sponsored by: CARiD
22re intake leak
Old Oct 12, 2018 | 05:08 PM
Larry Wyatt's Avatar
22re intake leak
I finished a complete rebuild on a 93 truck. I purchased it from someone who had overheated the motor. It had gotten so hot that the rods bent. I replaced them and new pistons. It fired right up and ran perfectly during my first warmup. I didn’t start it for another week as I was doing interior work on it. A week later when I started it again it ran rough with an air leak sound under the throttle body area. A friend suggested that since the engine had gotten so hot before the rebuild, maybe the intake manifold had weakened. Then when i warmed it up it cracked. I’ve taken off the throttle body and injector rail. Before taking off the manifold I’m asking if possibly someone else had an idea of another area to look at? Like I mentioned before, one weekend perfect. The next weekend an air leak. The bolts are torqued at 14lbs. Any ideas? I’ve read different threads on this forum for two years. This is my first time post asking for help. Thanks
Old Oct 14, 2018 | 08:52 AM
thefishguy77's Avatar
Spray starter around and listen for the engine to race. That will get you in the general area of the leak. You may have more than one leak...
If it got hot enough to bend the rods I hope you had the head and block checked. Aluminum heads melt before steel bends due to heat usually.
Old Oct 14, 2018 | 09:45 AM
Co_94_PU's Avatar
All moot..
Nothing to do now that you've taken it apart but put it back together..
A few things you could have checked. Idle valve air hoses firmly seated. Bolts not loosened up after the first heat cycle..
Bo
Oct 24, 2013 01:15 PM
wa4x4boy
Aug 14, 2009 04:26 PM
pcmentor
May 27, 2008 07:47 PM
95g ATL
May 2, 2006 04:58 PM
